Show only
Search instead for
I think in the hatch dialog box the default layer for hatch is missing , I mean by this option all hatches will stay on default layer which you can set. even you are working in deferent layers.
If the Ribbon is displayed, invoke the HATCH Command, on the Hatch Creation contextual tab, expand the Properties panel, and set the desired layer from the drop down list:
If the Ribbon is not displayed (to test, use RIBBONCLOSE Command), invoke the HATCH Command, and the Hatch dialog will be shown. In the Options pane at bottom right, there is a Layer drop down list.
