Publish window: allow to insert path
Dear Autocad users,
what is bothering since years by using the publish mode: when you choose the path, you need to click to the folder where you want to publish it. You can not insert a path in line. Usally I have the folder I'm working on open and it would be way easier just to copy/paste the publish path. As I usual I'm using a work-around (Autodesk favourite way to work): I create a shortcut on the desktop and I use the shortcut to get fast to the desired path.
If you could add the line, where you can copy paste paths it would make things 10x easier!
I added some screenshots how it looks like, and how it should look like
This idea would apply to all Autocad programs: Civil3D, Architecture...
1 Comment
TimYarris
Thank you for your idea. This would need to be addressed in core AutoCAD, but we will share this with the AutoCAD team for review while customers continue to add feedback and vote on it.
Rail Community
