When the drawing contains a recap file with more than 10.000.000 points and we create a surface from al the points with the command _AeccSurfaceFromPointCloud. Civil3D needs in that position good progressbar's so the users now what happens when working with AutoCAD Civil3D:
- Progressbar when save a drawing. (also with autosave)
- Progressbar when open a drawing (open file with surface from 10.000.000 points with mms file connected is slow. There is no need for new calculation off the surface when only open a file.)
- Progressbar when doing edits on a surface. For example past a surface from one to other surface
- ProgressIcon whet zooming and pan in the drawing with large data.
