Pasted surface interaction with abutting surfaces
Triangulation does not occur in gap areas when abutting surfaces that do not overlap are pasted into a single surface. Currently, the only way to create a smooth transition between the pasted surfaces is by adding the boundary of one of the surfaces as a breakline to the abutting surface. It would be nice if there was an option to allow triangulation to occur between the surface borders when pasted surfaces do not overlap.
1 Comment
The smooth surface option may be used to fill in the gap, but I find the process really hard to use and explain.
