Object Selection Sets
Use Case:
I often wish to select a set of disparate objects independent of other disparate objects. For example, I may want to select and then view in object viewer two separate surfaces, a gravity pipe network, and a pressure pipe network all at the same time.
Problem:
To do this now, I have to select these objects individually each time I want this selection set. This is OK, but what if I want to select these objects together over and over again. Well, as you can see, I have to do those same repetitive clicks over and over again too which is a huge waste of time.
Solution:
Allow me to create "Selection Sets" of objects. These "Selection Sets" could be a new tree node in the Toolspace. Maybe these "Selection Sets" are just folders to which I can add shortcuts to various objects in my drawing. Then, I would be able to quickly select the folder or "Selection Set" and instantly have access to that collection of objects all at once.
I look forward to seeing what can be done in this regard.
Sincerely,
Ryan
8 Comments
TimYarris
Status changed to: Gathering Support
@ryanlaughlin, I think the QSELECT command gets close to solving this requirement. The downside is that you're not able to save a selection set for reuse. Would saving the results of a QSELECT selection set get you what you're looking for?
ryanlaughlin
No. The selection set process uses filters to generate the set of objects.
Filtering would not allow for customized selection sets.
Thanks for your comment.
joantopo
You could try with "Group" object of AutoCAD.
joantopo
I think the ObjectViewer should ask us: Select Object or Group. If you select Group then it shows a drop-down list of all Groups in the drawing, so you could select a Group directly if you saved before.
Group would be set as non selectable.
If your group is selectable=Yes, then you can pick directly on the object but then we have to edit every time that Group (put Selectable Yes or Not every time).
ryanlaughlin
@joantopo I don't like this option because then you are asking the "group" feature to do double duty. I like using the "group" feature for easy drafting, moving, etc. Asking it to also be used for saving groups for viewing purposes is too much. I'd prefer to to be able to manage the objects that are selected using a tree/folder view so you can see at a glance which objects are part of that set.
Thanks for your comment!
TimYarris
Thanks for the idea, @ryanlaughlin. We will continue to evaluate it for possible future consideration as it gains support with other customers.
ryanlaughlin
Praise the gods, they finally listened. The new Model Viewer introduced in version 2026 resolves this issue. You can keep this viewer open while you make edits, add and remove various objects to the viewer, and they persist, and you can toggle on and off various objects in this viewer, so you don't constantly have to select the same objects over and over to view them in the object viewer.
Thank you for finally listening to your users, Autodesk!
ryanlaughlin
The new "Model Viewer" (not "Object Viewer") available in Civil 3D 2026 largely resolves this issue. You can add various components to the Model Viewer and the Model Viewer persists while you make changes to the model and you can turn on and off objects in the Model Viewer. This is a huge upgrade from the previous Model Viewer to the point that, at least for me, I believe this resolves my issue. Thanks, Autodesk.
