Use Case:
I often wish to select a set of disparate objects independent of other disparate objects. For example, I may want to select and then view in object viewer two separate surfaces, a gravity pipe network, and a pressure pipe network all at the same time.
Problem:
To do this now, I have to select these objects individually each time I want this selection set. This is OK, but what if I want to select these objects together over and over again. Well, as you can see, I have to do those same repetitive clicks over and over again too which is a huge waste of time.
Solution:
Allow me to create "Selection Sets" of objects. These "Selection Sets" could be a new tree node in the Toolspace. Maybe these "Selection Sets" are just folders to which I can add shortcuts to various objects in my drawing. Then, I would be able to quickly select the folder or "Selection Set" and instantly have access to that collection of objects all at once.
I look forward to seeing what can be done in this regard.
Sincerely,
Ryan
