No Profile - No Corridor Frequency - No more waterfalls
I want to add an option to the corridor frequency options so that corridors don't build when there is no profile data.. That way we prevent "off by one" erros that produce "waterfalls"  at the end of corridors.
We could add an option to the Frequency box called "Outside Baseline Profile Extents" and of course set the default to No...
So basically, no profile, no corridor
Hazaar!! Perfect!
4 Comments
TimYarris
Great idea, @ceethreedee.com !
joantopo
As a teacher of C3D years ago I had to explain always this scenario (waterfall) to my students.
I vote this idea!!!
joantopo
Under that option, in case you select "Yes", maybe another option called:
"Get report message if alignment is longer than profile" (this means that you have a gap in your profile or this  ends up before).
Sometimes you don't detect the crossfall if you don't use the Object Viewer or showing contours.
doni49
Not only should this feature be added, it needs to be the DEFAULT SETTING!  If someone wants to turn it off (WHY???), they should need to intentionally turn it off.
Rail Community
