More Profile Data Band options
Specifically, I need to label not just the difference between two profiles, but the grade between two profiles. Currently, there's Profile 1 minus Profile 2. I need Profile 1 minus Profile 2 divided by the horizontal distance between Profile 1 and Profile 2.
More broadly, we need more functionality from the data bands. Projected objects data on the data band is mentioned in another post - upvote that here... https://forums.autodesk.com/t5/autocad-civil-3d-ideas/data-projected-object-in-the-profile-view-band...
Basically, anything we can label, we might want to label in a data band. Please expand the functionality of Profile Data bands.
More requests for improvements to Profile bands:
https://forums.autodesk.com/t5/autocad-civil-3d-ideas/access-to-scales-in-band-labels/idi-p/5676884
https://forums.autodesk.com/t5/autocad-civil-3d-ideas/depth-to-invert-band-style/idi-p/5989941
https://forums.autodesk.com/t5/autocad-civil-3d-ideas/use-expressions-in-band-sets/idi-p/6279657
https://forums.autodesk.com/t5/autocad-civil-3d-ideas/setting-multiple-data-bands-at-once/idi-p/6207...
https://forums.autodesk.com/t5/autocad-civil-3d-ideas/civil-3d-pipe-network-profile-band-style-with-...
https://forums.autodesk.com/t5/autocad-civil-3d-ideas/band-set-for-pressure-pipe-networks/idi-p/5884...
2 Comments
Dexterel
I think almost all can be solved by adding Expressions to Band sets and the possibility to reference objects in expressions.
autoMick
Yes agreed. There are multiple ideas floating around requesting the availability of expressions for legend tables, etc. it would be a logical extension to make expressions available in band styles as well.
Cheers
- Mick
Rail Community
