If you select a material section, you can't check what was the quantity takeoff criteria to create it or how did you define that material in the criteria: its surfaces or code shape.
For example, if I remove that quantity takeoff criteria or I don't remember which was used, then I unknow the source of that material.
In section properties and in material list should appear this info. (The name of the quantity takeoff criteria)
