Incorporate an official tool or command to export Civil 3D tables
Kindly requesting to consider adding a tool or command that would allow users to export Civil 3D tables from projects.
As now, there is not such a function and this is a real need from Civil 3D users to submit projects results in XLS, CSV, XLSX, or other formats.
There is a third-party add-in that helps exporting tables, but it is hard to find and download. See the site: Civil3D: Civil Table Export
It should be a built-in functionality as the TABLEEXPORT command incorporated in AutoCAD.
Please, consider incorporating.
6 Comments
TimYarris
Thank you for your idea. Are you asking for the in-the-box Civil 3D tables, or AutoCAD tables?
Note that dynamic tables created with Project Explorer can be easily exported to a variety of formats.
MLentzZFHE4
@TimYarris We would like to be able to export Civil3D tables. For example, it would be helpful to be able to export a Pipe Table including size, length and slope to Excel to run analyses.
TimYarris
@MLentzZFHE4 , that example table/report combo can be done in Project Explorer.
I'll keep this idea on the list for core Civil 3D tables.
tcorey
Project Explorer is not 'official' enough?
tcorey
Hi @TimYarris ,
Despite my previous sarcastic comment, I do think this would be very useful, being able to press a button, select a table and specify an output format. It would be the same data format as the table, but as a file. It's easy enough to define a data output format if you understand Project Explorer, but this command would eliminate that often tedious and time-consuming step. Take the onus off the manager and give power to the users. I think the manager will appreciate it as she may have already been through a grueling exercise when creating the table style.
gleonhardt
in the DACH country kit is a functionalitry to export Civil tables to XLS.
Best regards
Gerald
