Export point in point groups using Project Explorer should uses Point and Point Label styles from point group
In the existing Project Explorer the Cogo point doesn't get Point group settings when using "Quick Export to 2D AutoCAD DWG File", instead user manually needs to add the Point Label Style and Point Style to every Point within the Point group which can cause incorrect information regarding layer, state, color etc because the Cogopoint will get the settings from the Point group "_All Points"
Idea or suggestion is that the export should read Point Group Settings and not settings from Point
