Enable option to change surfaces in a material definition
Kindly requesting to consider adding an option to change the surfaces in a material definition once it is set.
As of today, it is not possible to modify the surfaces involved into a material definition. To change it, it is necessary to remove the material and redefine it including the new desired surfaces.
Consider adding an option to simply change the used surfaces in the defined material.
1 Comment
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
