enable different annotation scales in model space viewports
A common workflow is to have profile or sections and plan view in side by side viewports, which usually are supposed to be displayed in different annotation scales. It would be nice if the annotative objects retained the original scale. Subsequently you would then wish the objects to retain the different scales after "Export to autocad".
1 Comment
robert06
Now, this was quick! Smiley Happy
Views and Viewports (new) – You can now easily create, retrieve, and place model views together with automatically sized and scaled layout viewports onto the current layout. When selected, layout viewport objects display two additional grips, one for moving the viewport, and the other for setting the display scale from a list of commonly used scales.
https://forums.autodesk.com/t5/autocad-civil-3d-forum/update-available-autocad-2018-1-1/td-p/7356588
Have not tested the functionality though as don't have 2018 yet.
