There is no way to specify sequence of rebuilding corridors when you select "Rebuild all corridors" in prospector. It would be very handy, because sometimes you can have several corridors which are dependent on each other (you are targeting to surfaces from corridors, feature lines, ...). And when you want to rebuild them, you have to do it manually, because you need to rebuild them in specific order.
