Corridor Targeting
Corridor Targeting
I really wish the the Horizontal Offset/Width targeting dialog had a button that would automatically assign the same feature line(s) as vertical targets after selecting them as horizontal targets. A simple checkbox for 'Use as Vertical Target' would be huge.
Same with alignments. If the alignment is assigned in the horizontal target dialog the vertical target dialog should automatically select this alignment and show the list of profiles without having to select the alignment again.
Better yet, how about combining the dialogs...
11 Comments
tcorey
Amen to this one. What a pain it is to pick horizontal and vertical targets separately when it's the same object.
robert06
This would be neat! Just check 'also a vertical target' when setting a horizontal target of a link (if enabled by assembly) or 'pick profile for vertical target' if the horizontal target is an alignment.
Tags (3)
jacob.dwyer
robert06
Exactly.
robert06
I did not come across this thread beforehand, the need is ancestral
https://forums.autodesk.com/t5/autocad-civil-3d-ideas/assign-corridor-offset-and-vertical-target-at-...
nizao_silva
Command (EDITCORRREGIONTARGETS)
My ideia is to when you go set a profile target in a corridor region(Slope or Elevation Targets), in Select Profiles From Drawing, if you select a profile, the software could automatically select the parent alignment and the profile
Tags (3)
This can be done allowing multiple selection on the assign target form, so one change of the name of the object will change all targets selected.
TimYarris
Status changed to: Accepted
Tracking internally as CIVIL-38465. This aligns nicely with other work we're doing on the corridor targeting workflows.
jmayo-EE
robert06
TimYarris
You're welcome, @robert06 , but I don't think we've quite satisfied the original idea yet. A checkbox to use the same object as both horizontal and vertical target just missed the cutoff for 2022.1. It's still on the list, so stay tuned.
