A pipe crossing label that would give you the "depth of cover".
To whom,
I.e. the alignment crosses a pipe and the label would tell you the depth of cover at that particular crossing.
1. The label would reference a surface and alignment so it would update as the alignment crosses the pipe in different locations.
2. It would give you a distance from the surface to the top outside top of pipe at that crossing location.
3. The crossing label would follow the pipe location in profile as alignment changes are made.
4. It gives you the depth of cover of pipe crossing label at the start and end of a pipe from the surface.
Just need it to give me that cover at the alignment crossing.
Thank you,
Jason Amundsen
1 Comment
tom.buhler
It would also be great to add the functionality to add expressions. The idea being you could specify "cover" based on (target surface) - (top of pipe) ± (value).
This way you could modify the cover for situations where you need to go from your "top of road" profile to "top of subbase" or "top of rail" to "base of rail".
Answer Day
Rail Community
