When adding a widening to an alignment, the widening is limited to the current Command settings. This includes the transition type, default taper input type, default transition length, default taper ratio, default radius for Curve 1, 2 and 3, widening offset and widening segment length.
I would like a dialog box so these choices and values could be chosen when creating the offset, rather than setting some default and modifying the widening every time to get the actual widening desired. For example, choose what type of transition desired, then chose the settings for input type, transition length or taper ratio, radii for Curve 1, 2 or 3, widening offset, and segment length. Perhaps have a begin and end station option. Add a widening from this station to that station and hold the offset before and after the widening.
