Add elevation label for Feature Lines
Hi.
Surface label is really good to see elevations graphically. In my opinion, Feature Lines should have something similar. A way to add elevation labels on the FL, so were able to see elevations in the drawing. Even labels of slope, Delta Y between points/elevation points.
Thanks in advance.
4 Comments
TimYarris
Thank you for your idea. The development team will review the idea while customers continue to add feedback and vote on it.
I think Civil3D is available with the feature you mention. We can label the feature line with " Line and Curve". Some adjustments with the available label for level, distance, slope or more can be generated to suit your purpose.
TimYarris
Thanks for sharing, @charles_phanMGMAJ . When I tried using the basic line/curve labels, I was able to add a reference text component to get a surface elevation, but not the elevation of the feature line itself. I believe that is what @joantopo is requesting.
joantopo
Yes!!
It works!!
15 years using Civil 3D and I did not know it!!!
You have to create 2 components to show elevation in the start and end of the segment.
I think that c3d template should incorporate this label style by default.
