acad dimension continue possibility
  There is a possibility to use command as DimContinue, that dimensions that are  added are linked in a single dimension line and as such displaced in the drawing, namely angles are independent and if you need to move you must select each individual, in large designs sometimes has a 30-40 dimensions in same line , to move it on the desired position is that possible to do it at once witout selection on each dimension?
1 Comment
troma
Have you tried the DIMSPACE command?
Rail Community
