Ability to Add Additional Profile View Add Crossing to the Current List
Currently if you add alignments, profiles, & featurelines to the Add Crossing feature of the profile View properties the list is a onetime only.  You cannot add additional crossing to the existing list without starting all over by selecting each object again along with the additional objects.  Then on top of getting the list populated then you have to change the object style and label style for each crossing.  The default setting does not distinguish between alignments, profiles, & featureline so you have to go through all of them and choose the appropriate style for each.  The idea is to allow for additional crossings to be added on to the current list without haveing to start over with the entire new list.  The other idea would be to add more default setting for the style & Label for the separate alignments, profiles, & featurelines.  Currently, the "pick Objects" button in reality is a start over button.  It should allow you to make additional selections.
