Zombie Aerial!
Zombie Aerial!
arobinson02G4RKZ
Zombie Aerial!
arobinson02G4RKZ
Hey Folks,
Here's an odd one. Got a set of plans that an aerial appears in, but I don't want it. Well, the aerial is in an xref, it's in a base file. However, when I open that base file the aerial is nowhere to be found! When I pull up the xref listing it's not there! So, where could it be? Any ideas? I need to get rid of this aerial, but there doesn't appear to be any xref, link or other means of connection between it and the drawings. I can't even list it as it's technically in an xref.
user181
Is it the geolocation map built into autocad?  In each drawing try the command GEOMAP and then the OFF option.
If it is a geomap they may have used the capture area. If so select the map and if the properties palette says it's a geomap image you can also erase or freeze it.
jroot
If it's not a GEOMAP thing like @user181 suggested and there actually is an image of some kind, it must reside on a layer. You could trial-and-error turning layers off/on to see if it goes away.
ChicagoLooper
Open the Xref. Is the image selectable?
To be selectable, IMAGEFRAME=1?
If it’s selectable, what is the description displayed at the top of the Properties Palette when image is selected?
Chicagolooper
Kevin.Spear
Another option is inserting images using data connect in Map3D. open the map task pane (MAPWSPACE>ON) and see if an image is listed on the display manager tab. you can either toggle the check OR use the DATA CONNECT (MAPCONNECT) palette to DISCONNECT the raster image.
Kevin
Kevin Spear, PE
brian.strandberg
Try setting FRAME to 2.  If it is set to 0,1 or 2 it will override IMAGEFRAME.
You can also try the express tools ssx.  Type in SSX, it will ask you to select an object, press enter.
Hit E for Entity and type in IMAGE - this will search for all "image" objects.
As everyone else has discussed, there are several different objects that can be displaying your image (geomapimage, image, AutoCAD Map FDO connection.)
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
arobinson02G4RKZ
Thanks, people, I managed to work it out. In the end, I just went old school: I deleted the image from the drawing! When I tried using the geoimage command, it didn't do anything. So, I just got rid of it.
