Yellow icon on intersection at toolspace
fiyahe7981
fiyahe7981
Good day,
I have noticed two yellow icons on the intersection on my toolspace. I have tried updating the corridor by=ut the icons still shows. What did i not get right? Attached is the drawing
Dexterel
To eliminate the yellow notice you need to update the intersection and rebuild the corridor.
I suggest to ignore this message because your corridor regions and targets will be recreated and next time you open your file you get the same  notice. Because the intersection is dependent on the offset aliments and profiles. I think the offset alignments are recreated when you reopen the DWG and this sends a message that the intersection is out of date. I think its safe to ignore the yellow notice.
