Xref not attaching properly showing circles and rectangles
vinayak_bandi
vinayak_bandi
hi,
If i attach xref file in civil 3d it is showing unwanted circles & rectangles & original drawing is not visible
plz see images
image 1 is civil 3d file
image 2 is autocad file
i am using 2023 licensed version
requesting to suggest
Pointdump
Hi Vinayak,
Please post both drawings.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
vinayak_bandi
PFA
Quantity for Playa De Biomasa - civil3d file
ESQUEMA PLAYA DE BIOMASA REV 3 - Copy - Autocad file
we need to attach the autocad file in civil 3d file by using xref
even scale is the issue
brandon_short7ZXV7
Did you check whether layers are turned off or frozen?
brian.strandberg
If you XLIST those can you figure out what it is?  Thanks.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
vinayak_bandi
Actually there were 2 drawings in the same file the drawing was in minimum scale
