Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The External References palette appears when I run the XREF command. I select the Attach Drawing button and select a .dwg file from the file dialog. The command line shows that Civil 3D ran _XATTACH. Then nothing happens.
The Attach External Reference file dialog does not appear. I am able to back out of the command using the Esc key.
The .dwg files I am working with are stored on my hard disk, but the same issue occurs with all files whether stored locally or on a network. I am currently running Civil 3D version 2020.6.1 on top of AutoCAD 2020.1.4. Thank you for your help!
