Corridor Feature Lines Not Drawn when alignment layer is locked
wmillerYCXX2
Observer Observer
wmillerYCXX2
Observer
Observer
Just thought we'd share in case anyone else comes across this issue. We had a corridor modeled and everything was appearing correctly. We made changes at a point and lost the feature lines in the corridor that connected the point codes we want to show horizontal linework for. The change we made that caused this issue was locking the layer our alignment was on. We did this so we wouldn't move it by mistake. But locking the layer caused the corridor to have display issues. Just a thought to check locked layers if you run into this issue.
rl_jackson
@wmillerYCXX2,
I have rarely if ever used locked layers, and I can see why it would cause issues with FL layers in a corridor that are Dynamic, and Thanks for the warning.
Maybe @samir.rezk or @lim.wendy  could adjust this forum description to fit the issue, more precisely.
Rick Jackson
Survey CAD Technician VI
lim.wendy
Hi @wmillerYCXX2 ,
Thanks for sharing this. Could you share the steps to reproduce this problem?
@rl_jackson,
Thanks for letting us know.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Jeew-m
I have experienced that when you use a locked layer even the targeting of the corridor also experiences problems.
As for your problem, I would suggest you use data shortcuts.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
