Civil 3D Forum
XCOMPARE files and folder size
3 REPLIES 3
neilyj666
1197 Views, 3 Replies
My XCOMPAREBAKSIZE folder is set to 500 Mb but the properties indicate it is significantly larger which isn't a major issue although I have now moved it to my 😧 drive.
My real question is should the files in this folder be regarded as temporary files which can be deleted every now and then if desired?
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
3 REPLIES 3
pendean
in reply to: neilyj666
It is a temp folder AutoCAD2021 uses while you are comparing files: it is not tied to your actual source files.
I point that folder's location in OPTIONS command to my Windows log-in %TEMP% folder and I'm not seeing any issues so far.
neilyj666
in reply to: pendean
Thanks for the reply - I think I'll also point it to %TEMP%.
It seems a little odd that it isn't pathed to this location by default
pendean
@neilyj666 There are lots of non-permanent files that need to be pointed to the %TEMP% folder IMHO in OPTIONS's FILES tab, starting with all the ones labelled "temporary" to log files locations. I've never had issues over the years with redirecting them.
Rail Community
