My XCOMPAREBAKSIZE folder is set to 500 Mb but the properties indicate it is significantly larger which isn't a major issue although I have now moved it to my 😧 drive.
My real question is should the files in this folder be regarded as temporary files which can be deleted every now and then if desired?
Solved by pendean. Go to Solution.
It is a temp folder AutoCAD2021 uses while you are comparing files: it is not tied to your actual source files.
I point that folder's location in OPTIONS command to my Windows log-in %TEMP% folder and I'm not seeing any issues so far.
Thanks for the reply - I think I'll also point it to %TEMP%.
It seems a little odd that it isn't pathed to this location by default
