X-Section info
X-Section info
kina_86
X-Section info
kina_86
Hello!
Where i can find more informatiom about (x-sect):
Band type - Section Data and Section Segment ();
Labels and ticks (Major increment, minor increment, centerline, sample line vertices, grade breaks, incremental distance).
I want to learn more but i can't handle with this forum...
Thanks!
Matheus-Lima
Hi, @kina_86!
I would take a look at Civil 3D Help, there's a lot of tutorials and guides like this one: https://help.autodesk.com/view/CIV3D/2023/ENU/?guid=GUID-B1ABC52D-2EF8-4CB7-AB3A-17EB8496AFCE.
Cheers,
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
