Wrong Sheet Set template used for project. Replace?
RobertEVs
Advisor Advisor
RobertEVs
The incorrect template for a Sheet Set project was used which means Sheet Set Custom Properties is missing. The SS is already populated with several drawing layouts. Is there a way to create a new correct SS and exchange it with the old one which means ALL Layouts?
BrianHailey
Not that I'm aware of but I would be very interested to hear if there was some way of doing that.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
neaton
Not sure if it would work, but can you use JTB World's SSMPropEditor to export to Excel and change the header names then import back to C3D?
RobertEVs
I'm finding the easiest way is simply to edit the Non-Compliant SS Properties and ADD new Custom Properties to match the those of the template. Thanks for the input.
