Working Folder path changes itself
slant
slant
Windows 7, Civil 3D 2014
Every day when i come in and open my project, the working folder is set back to an old job that i finished more than a year ago and have not revisited. Once i reset the working folder to the correct project, it stays that way all day. The next morning, however, it has reverted back to the old working folder. Is it possible to lock it somehow so that it stops changing itself overnight?
Replies (25)
ilia.borisov
Try that
brendan.collum
Observer
Observer
This didn't seem to work either. it only seems to be this particular file as well, the others I can manipulate however I desire
stephenbrooks410
I am getting the same problem in Civil 3D 2019. At random when the file is open the working folder changes by itself. It is changing to a Projectwise data shortcuts folder. The project I am currently working on is not on Projectwise (thank God). This does not seem to be affecting the objects that are referenced into the file from the original (correct) data shortcuts working folder and project folder.
simon.connellRBKGZ
I am using C3D 2021 and am getting this problem. Frustrating to see it goes back 6 years!
B_Rob
C3d 2024 same problem...have not found a solution
EDIT: I might have found a solution: Try the system variable: SHORTCUTASSOCIATEENABLE
It seems to be working (my working folder and associated  project are now sticking.
C3D_TomR
The resolution I found to this issue was to set LoadRecentDSProjectOnStartup to ON.
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
