Announcements
Automating Text Selection and Color Change in Civil 3D: Seeking Guidance for Beginners
erlanlirajr
Observer
erlanlirajr
Observer
Observer
Hello. I'm trying to automate a task in Civil 3D, but I'm a beginner. The idea is to create a script that selects all "text" or "mtext" with a specific height and changes the color of these found elements. Note: this would be in the layout, and there are projects that reference the model with different scales. Could someone help me with how this automation could be done? Thank you!
Joe-Bouza
Go in a layout of one of you files.
start the action recorder give the macro a sensible name. QSELECT  filter text by height>> change property. QSELECT,mtext by height >>change property>>>QSAVE.
stop recording . Test it and adjust if needed.
find your acaddoc.lsp file in windows explorer and open in note pad.
add this to the file:
(COMMAND “macro name”)
save a close.
back to acad. using Sheet set manager or PUBLISH the layouts you need to change
When done go back to acaddoc.lsp and add REM in front of the Caio and we previously added
Joe Bouza
