Since a while C3D 2022 crashes after a few minutes of work when there's a WMS connection underlay added from local database (http://kaart.maaamet.ee/wms/alus? version 1.1.1). Thought it was a issue with Civil 2022 only but it appears in 2021 as well, while it used to work fine until 2022 was installed. Could there be a setting to fix this? Do you experience this also with other gis environments?
Hi Robert,
The only one I could get working was "Halduspiirid". No crashes.
Dave
Dave Stoll
Las Vegas, Nevada
It connects to the server, all the gis layers are available as they should and it does not crash at once.
But in a short while firstly standard autocad objects appear to be unselectable and fatal error follows.
It does not appear just with my profile and system but also others in the office, but not all users. So I asume there is a setting or variable which might impact the occurance.
I have experienced similar issues with WMS. Where may we find more guidance on using the WMS and the preferred settings.
