Wipeout Command Issues: Plots show slight transparency when printed but same PDF plot prints fine from a separate computer.
alaina64XMN
alaina64XMN
Community Visitor
Community Visitor
The plotted PDF prints fine from my coworkers computers with the same setting.
I've tried playing around with layer transparency and unchecking/checking plot transparency in the plot window, plot to print is on for the wipeout, display order, wipeout in paper space vs model space, Lines- overwrite to Lines merge in Plot Settings, wipeoutframe 0 and 2, wipeout changed to true color white, changed file type in adobe. Lastly, I don't want to switch workflow to use background hatch instead of wipeout as an option.
chriscowgill7373
Are you sure it is the same setting?  Just because the Pc3 file is named the same, doesnt mean it is the same, unless you are both pulling from a single location.  What pc3 file are you using for plotting?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
obulesub
Hi @alaina64XMN,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Obulesu | Community Manager
obulesub
Hi @alaina64XMN ,
I wanted to check in and see if you saw chriscowgill7373  follow up questions or if you still needed assistance. If you found a solution to your question already, please share the details so that other community users can benefit from the information.
