Civil 3D Forum
window problem
8 REPLIES 8
Message 1 of 9
322 Views, 8 Replies
window problem
here is the problem....
8 REPLIES 8
Message 2 of 9
Alfred.NESWADBA
Which problem?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 9
in reply to: Alfred.NESWADBA
the window for my autocad.  It was full screen, the x to close it was up near the right hand corner..
if I open a new dwg, it wont fit full screen, that is even as big as the other blue bounded window......
Message 4 of 9
pendean
Is this a new install of C3D2017? Or a new Win10 installation?
Are you running dual (or more) monitors, or one single monitor?
Is this a laptop screen?
Message 5 of 9
in reply to: pendean
C3D 2017 ON WINDOWS 10
Dual monitors from a laptop
it has worked for 2 months
I have tried
set properties in short cut run: maximum
tried taskbar 0 then 1 and back again.
tried cleanscreen on and off and on etc
thankyou
Message 6 of 9
GrantsPirate
Pretty sure you just need to pick on the Maximize button in the graphics window and not the most upper right one.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 7 of 9
Alfred.NESWADBA
Just click here, then the drawing-window is maximized within AutoCAD:
- alfred -
Alfred NESWADBA
Message 8 of 9
in reply to: GrantsPirate
nope.   what's worse is everytime I  open a new dwg in one session the window is smaller at maximize....
Message 9 of 9
Rail Community
