Width limit for corridor offset targets
jessica.miller
jessica.miller
Does anyone know if there is a place to set the width limit for a corridor to look for offset targets?  I have an alignment with several curves & the corridor is finding targets from beginning of the project that do not correspond to the end of the alignment.  If I could set the width limit to 500' or so from the baseline this would fix the problem I'm having.
Jessica Miller
Design Technician
CEC Corporation
4555 West Memorial Road, Oklahoma City, OK 73142
T: 405.753.4200
Dir: 405.753.4616
www.connectcec.com
KMercier_C3D
Is there a specific subassembly that you are seeing this issue with?
Conditional Horizontal Targets have a Maximum Distance input parameter:
For other target subassemblies you may want to look at the Target to Nearest Offset setting on the Target Mapping of the corridor.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
mohammad.kourani2012
Even if you use the suggested workflow (the normal workflow), the software has glitch and you have to assign every side its separate targets.
