Changing A Linetype Definition, With No LIN File That Is In A Template
Message 1 of 13
I am working in AutoCAD Civil 3D 2016 & 2018, and I have linetypes incorporated into a drawing template a former coworker created. I cannot modify the linetype definitions of the linetypes due to them being incorporated into the template without an LIN file. Is there any way to change a linetype definition when no LIN file is associated? (We are required to use these linetypes even though we are permitted to modify them, oddly enough) Also, sorry if this isn't enough detail to go off of.
Replies (12)
Message 2 of 13
rkmcswain
Grab either TO-LIN.lsp or NEW-LIN.lsp from the site below, to extract one or all linetype definitions from a DWG file to a .LIN file.
TEE SQUARE GRAPHICS
(BTW: You can edit the linetype definition inside the DWG file, but it would require using some sort of programming, such as autolisp)
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 13
That looks like it would do it, unfortunately only our IT is permitted to run LISP Routines...
Message 4 of 13
rkmcswain
If you can attach a stripped down* version of your .DWG that contains the linetypes, I'll extract the .LIN file(s) for you.
(*stripped down means erase everything visible and just leave the linetype defs in the .dwg)
Message 5 of 13
Thank You for your help
Message 6 of 13
rkmcswain
;; New LineType descriptions extracted
;; from existing drawing(s) by NEW-LIN.LSP.
;; NEW-LIN.LSP (c) 2000 Tee Square Graphics
*pCF,Proposed Construction Fence ---- CF ----
A,1,-0.08,
["CF",STANDARD,s=0.08,r=0,x=-0.055,y=-0.04],
-0.08
*pCL, ---------- - ---------- - ---------- - -------
A,1.25,-0.05,0.1,-0.05
*pCL2,----- - ----- - ----- - ----- - -----
A,0.75,-0.025,0.05,-0.025
*pES,-------- -------- --------
A,0.75,-0.05
*pESMT,-------- - - -------- - - -------- - - ----
A,1,-0.1,0.1,-0.1,0.1,-0.1,0.1,-0.1
*pFENCE,Proposed Fence ---- X ----
A,1,-0.001,
["X",STANDARD,s=0.08,r=0,x=-0.027,y=-0.04],
-0.001
*pLOT,-------- - - -------- - - -------- - - ------
A,0.75,-0.09,0.09,-0.09,0.09,-0.09
*pPL,-------- - - -------- - - -------- - - ------
A,1.25,-0.1,0.15,-0.1,0.15,-0.1
*pROW,-------- - - -------- - - -------- - - --------
A,1.25,-0.1,0.2,-0.1,0.2,-0.1
*pSTONE,------- ------- ------- ------- -------
A,0.5,-0.03
*pZONE,__ . __ . __ . __ . __ . __
A,0.1,-0.04,0.05,-0.04
*xGR,Existing Guiderail
A,0.5,
["o",STANDARD,s=0.07,r=270,x=0,y=0],
-0.044
*xSETBACK,----------  ----------  ----------  --------
A,1,-0.25
*DASHED2,Dashed (.5x) _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
A,0.25,-0.125
*pSDPIPE,- - - - - - -
A,0.1,-0.05
*pTC,Proposed Time of Concentration Path ---- >>> --
A,0.5,-0.001,
[">>>",STANDARD,s=0.11,r=0,x=-0.1,y=-0.047],
-0.001,0.5,-0.07,
[">>>",STANDARD,s=0.08,r=0,x=-0.07,y=-0.04],
-0.07
*pCONTTEMPinter,- - - - - - - -
A,0.03,-0.03
*pCONTTEMPindex,- - - - - - - -
A,0.06,-0.03
*pCOND,Proposed Conduit ---- COND ----
A,1,-0.14,
["COND",Standard-N,s=0.08,r=0,x=-0.15,y=-0.04],
-0.14
*pE,Proposed General Electric Line ---- E ----
A,1,-0.07,
["E",STANDARD,s=0.08,r=0,x=-0.025,y=-0.04],
-0.07
*pUE,Proposed Underground Electric Line ---- UE ----
A,1,-0.1,
["UE",STANDARD,s=0.08,r=0,x=-0.06,y=-0.04],
-0.1
*pISO,- - - - - - - - - - - - - - - - - - - - - -
A,0.15,-0.05
*pRSF,Reinforced 30" Silt Fence ---- RSF ----
A,0.8,-0.115,
["RSF",STANDARD,s=0.08,r=0,x=-0.095,y=-0.04],
-0.115
*pSF,Standard 18" Silt Fence ---- SF ----
A,0.8,-0.085,
["SF",STANDARD,s=0.08,r=0,x=-0.055,y=-0.04],
-0.085
*pSSF,Super Silt Fence 33" ---- SSF ----
A,0.8,-0.115,
["SSF",STANDARD,s=0.08,r=0,x=-0.095,y=-0.04],
-0.115
*xMUNIx2,--------- - --------- - --------- - ---------
A,0.6,-0.1,0.2,-0.1
*SMDASH,- - - - - - - - - - - - - - - - - - - - - -
A,0.1,-0.05
*pSS,Standard Silt Sock ---- SS ----
A,0.8,-0.085,
["SS",STANDARD,s=0.08,r=0,x=-0.055,y=-0.04],
-0.085
*xCONTindex,-- -- -- -- -- -- -- -- -- -- -- -- -- --
A,0.16,-0.08
*xCONTinter,- - - - - - - - - - - - - - - - - - - - - -
A,0.06,-0.05
*pCATV,Proposed CATV Line ---- CATV ----
A,1,-0.14,
["CATV",Standard-N,s=0.08,r=0,x=-0.14,y=-0.04],
-0.14
*pIRR,Proposed Irrigation System Line ---- IRR ----
A,0.8,-0.09,
["IRR",Standard-N,s=0.08,r=0,x=-0.08,y=-0.04],
-0.09
*pGAS,Proposed Natural Gas Line ---- G ----
A,1,-0.07,
["G",STANDARD,s=0.08,r=0,x=-0.04,y=-0.04],
-0.07
*pOIL,Proposed Oil Line ---- OIL ----
A,1,-0.1,
["OIL",Standard-N,s=0.08,r=0,x=-0.07,y=-0.04],
-0.1
*pRDPIPE,Proposed Roof Drain Line ---- RD ----
A,0.5,-0.07,
["RD",Standard-N,s=0.08,r=0,x=-0.05,y=-0.04],
-0.1
*pSANPIPE,Proposed Sanitary Sewer Line ---- S ----
A,1,-0.06,
["S",STANDARD,s=0.08,r=0,x=-0.03,y=-0.04],
-0.06
*pUT,Proposed Underground Telecom Line ---- UT ----
A,1,-0.1,
["UT",STANDARD,s=0.08,r=0,x=-0.06,y=-0.04],
-0.1
*pWLPIPE,Proposed Water Line ---- W ----
A,1,-0.07,
["W",STANDARD,s=0.08,r=0,x=-0.04,y=-0.04],
-0.07
*xCL, ---------- - ---------- - ---------- - -------
*xEM,----- ----- ----- ----- ----- ----- -----
A,0.5,-0.05
*xESMT,----- - - - ----- - - - ----- - - - -----
A,1,-0.05,0.1,-0.05,0.1,-0.05,0.1,-0.05
*xES,-------- -------- --------
A,0.75,-0.05
*xWATER,-------- - - - ------------ - - - ----------
A,1,-0.1,0.02,-0.1,0.02,-0.1,0.02,-0.1
*xFENCE,Existing Fence ---- X ----
A,1,-0.01,
["X",STANDARD,s=0.06,r=0,x=-0.02,y=-0.03],
-0.01
*STACKADE_2, Stockade Fence without spaces
A,0.75,-0.05,
[{Shape #132},AECCLAND,s=0.025,r=0,x=-0.025,y=0],
-0.05,0.5
*xPLAJ,------- - - --------- - - -------- - - -----
A,0.7,-0.04,0.08,-0.04,0.08,-0.04
*xPL,------------ - - -------------- - - ---------
A,1.25,-0.05,0.1,-0.05,0.1,-0.05
*xLRW,-------- - - - ---------- - - - -------- - - -
A,1.25,-0.05,0.15,-0.05,0.15,-0.05,0.15,-0.05
*pSAWCUT,- - - - - - - -
A,0.2,-0.06
*xSTONE,------- ------- ------- ------- -------
A,0.4,-0.05
*xUCATV,Existing Underground CATV Lines ---- UCATV ----
A,1,-0.15,
["UCATV",Standard-S,s=0.06,r=0,x=-0.155,y=-0.03],
-0.15
*xOE,Existing Overhead Electric Lines ---- OE ----
A,1,-0.07,
["OE",Standard-S,s=0.06,r=0,x=-0.06,y=-0.03],
-0.07
*xOET,Existing Overhead Electric & Telecom Lines ----
A,1,-0.08,
["OET",Standard-S,s=0.06,r=0,x=-0.075,y=-0.03],
-0.08
*xUET,Existing Underground Electric & Telecom Lines -
A,1,-0.08,
["UET",Standard-S,s=0.06,r=0,x=-0.075,y=-0.03],
-0.08
*xUE,Existing Underground Electric Lines ---- UE ---
A,1,-0.07,
["UE",Standard-S,s=0.06,r=0,x=-0.06,y=-0.03],
-0.07
*xGAS,Existing Underground Natural Gas Line ---- G --
A,1,-0.06,
["G",Standard-S,s=0.06,r=0,x=-0.025,y=-0.03],
-0.06
*xSANPIPE,Existing Sanitary Sewer Pipe ---- S ----
A,1,-0.06,
["S",Standard-S,s=0.06,r=0,x=-0.03,y=-0.03],
-0.06
*xSDPIPE,-- -- -- -- -- -- -- -- -- -- -- -- -- -- --
A,0.2,-0.05
*xOT,Existing Overhead Telecom Lines ---- OT ----
A,1,-0.07,
["OT",Standard-S,s=0.06,r=0,x=-0.06,y=-0.03],
-0.07
*xUT,Existing Underground Telecom Lines ---- UT ----
A,1,-0.07,
["UT",Standard-S,s=0.06,r=0,x=-0.06,y=-0.03],
-0.07
*xUNK,Existing Underground Unknown Lines ---- UNK ----
A,1,-0.15,
["UNK",Standard-S,s=0.06,r=0,x=-0.11,y=-0.03],
-0.15
*xWLPIPE,Existing Water Pipe ---- W ----
A,1,-0.06,
["W",Standard-S,s=0.06,r=0,x=-0.03,y=-0.03],
-0.06
*xTC,Existing Time of Concentration Path ---- >>> ---- Tc ----
A,0.5,-0.001,
[">>>",Standard-S,s=0.11,r=0,x=-0.1,y=-0.047],
-0.001,0.5,-0.07,
[">>>",Standard-S,s=0.08,r=0,x=-0.07,y=-0.04],
-0.07
*xMUNI,--------- - --------- - --------- - ---------
A,0.3,-0.1,0.1,-0.1
*xSOILS,---------  ---------  ---------  ---------
A,1.25,-0.25
*xZONE,__ . __ . __ . __ . __ . __ . __ . __ . __
A,0.2,-0.05,0.04,-0.05
*xOCATV,Existing Overhead CATV Lines ---- OCATV ----
A,1,-0.15,
["OCATV",Standard-S,s=0.06,r=0,x=-0.155,y=-0.03],
-0.15
*xFENCE2,Existing Fence 2 ---- X ----
A,0.5,-0.01,
-0.01
*xUFO,Existing Underground Fiber Optic Lines ---- UFO
A,1,-0.08,
["UFO",Standard-S,s=0.06,r=0,x=-0.075,y=-0.03],
-0.08
*xSANFM,Existing Sanitary Force Main ---- FM ----
A,0.75,-0.08,
["FM",Standard-S,s=0.06,r=0,x=-0.06,y=-0.03],
-0.08
*pDATA,Proposed Data Transmission Line ---- DATA ----
A,1,-0.14,
["DATA",Standard-N,s=0.08,r=0,x=-0.14,y=-0.04],
-0.14
*pFW,Proposed Fire Water Line ---- FW ----
A,1,-0.1,
["FW",STANDARD,s=0.08,r=0,x=-0.06,y=-0.04],
-0.1
*pOCATV,Proposed Overhead CATV Line ---- OCATV ----
A,1,-0.16,
["OCATV",Standard-N,s=0.08,r=0,x=-0.19,y=-0.04],
-0.16
*pOE,Proposed Overhead Electric Line ---- OE ----
A,1,-0.1,
["OE",STANDARD,s=0.08,r=0,x=-0.06,y=-0.04],
-0.1
*pOET,Proposed Overhead Telecom Line ---- OET ----
A,1,-0.12,
["OET",STANDARD,s=0.08,r=0,x=-0.1,y=-0.04],
-0.12
*pOT,Proposed Overhead Telecom Line ---- OT ----
A,1,-0.1,
["OT",STANDARD,s=0.08,r=0,x=-0.06,y=-0.04],
-0.1
*pSANFM,Proposed Sanitary Force Main ---- FG ----
A,1,-0.1,
["FM",STANDARD,s=0.08,r=0,x=-0.06,y=-0.04],
-0.1
*pT,Proposed General Telephone Line ---- T ----
A,1,-0.07,
["T",STANDARD,s=0.08,r=0,x=-0.025,y=-0.04],
-0.07
*pUCATV,Proposed Underground CATV Line ---- UCATV ----
A,1,-0.16,
["UCATV",Standard-N,s=0.08,r=0,x=-0.19,y=-0.04],
-0.16
*pUET,Proposed Underground Electric & Telecom Line --
A,1,-0.12,
["UET",STANDARD,s=0.08,r=0,x=-0.1,y=-0.04],
-0.12
*pUNDERDRAIN,Proposed Underdrain ---- UD ----
A,0.7,-0.1,
["UD",Standard-N,s=0.08,r=0,x=-0.1,y=-0.05],
-0.1
*pSANLAT,Proposed Water Lateral 2 ---- S ----
A,0.2,-0.035,
["S",STANDARD,s=0.05,r=0,x=-0.025,y=-0.025],
-0.035
*GRID,- - - - - - - - - - - - - - - - - - - - - - - -
A,0.05,-0.05
Thanks @Anonymous
Message 7 of 13
Thank You for your help!
Message 8 of 13
sconroy
OK - Dumb question but where does TO-LIN save the file?
Message 9 of 13
AllenJessup
I'd suggest searching your computer for NEWLT.LIN. The path isn't explicit in the lisp file. (At least that I can see).
Allen Jessup
CAD Manager - Designer
Message 10 of 13
sconroy
yup - did that first thing.
 I did a search on my c:\ drive as I would expect it to go there and nothing, I then did a search on the server drive and nothing; File location - no; drives specified in the files tab in AutoCAD - nothing...
I'm assuming the file didn't write, but was trying to rule out a hidden directory - which my search tool 'agent ransack' still searches, but you never know. I also took a look in the lisp routine (not that I'm the shakes with programming mind you) and I couldn't see any path and was hoping to identify where in the program it specifies the path so I could change it.
Long story short - for me this program doesn't work, nor does new-lin.lsp.
I did however find a good workaround for this here: https://www.cadstudio.cz/en/download.asp?file=LinOut
Message 11 of 13
AllenJessup
Interesting. I've never used To-Lin but have used  New-Lin in the past. It's possible they don't work in newer versions of AutoCAD.
Allen Jessup
Message 12 of 13
rkmcswain
They both still work just fine in AutoCAD 2020.
Message 13 of 13
rkmcswain, I am having trouble trying to use the link you posted above. I want to use the command NEW-LIN.lsp but do not understand how. When I click on it, it opens up a text file. What do I do from there?
