Where to export to FBX format in Civil3D 2019?
alexey.kurenkov
Advisor Advisor
Message 1 of 29
alexey.kurenkov
Our client used to export objects to the FBX format used in workflows. On what basis did you delete the export to FBX format?
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку 'УТВЕРДИТЬ РЕШЕНИЕ' | Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Replies (28)
Message 21 of 29
neilyj666
Yes the thread title refers to 2019 - I think it was provided as a one off for that product and has not been provided for 2020.
I don't understand why it was dropped as it was more straightforward IMHO as you remain in familiar AutoCAD territory and avoid having to learn what to do in 3Ds Max
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 22 of 29
chriscowgill7373
I tried, unless I'm typing it wrong.
https://autode.sk/2WAptCz
is what I see and typed and it takes me to the main autodesk page.
@Alfred.NESWADBA is correct, in that a plugin for 2019 wont do much good for 2020, which was going to lead to a follow up question, as to whether or not there has been one developed for 2020.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 23 of 29
neilyj666
https://viewer.autodesk.com/share/ZFhKdU9tRmtjMnN1Ym1sMGNtOW5aVzQ2Wm5NdVptbHNaVHBqT1RSbE5UUTBOMkk0T0...
Message 24 of 29
chriscowgill7373
Thanks, I'll give that a shot.
Message 25 of 29
hanslammerts
Where is the FBX export addin fix.
Message 26 of 29
DarrenP
there isn't one anymore
Autodesk has removed the add in for 2019 from their website
DarrenP
Message 27 of 29
DarrenP
DarrenP
Message 28 of 29
hanslammerts
With BricsCAD SHAPE you can export a DWG model to FBX.
https://www.bricsys.com/en-intl/bricscad-shape/?
Message 29 of 29
andrewofabley
Bumping this for relevance
@hanslammerts
@DarrenP
@chriscowgill7373
@neilyj666
@alexey.kurenkov
@dgorsman
@liam.mulcahy
Consider using the self service tool I recently posted: https://forums.autodesk.com/t5/civil-3d-forum/autocad-dwg-to-fbx-conversion-a-solution/td-p/10088691
Available here: https://devfme.abley.com/fmeserver/apps/DWGtoFBX
AEC Collection / Safe FME / ESRI ArcGIS / Unreal Engine
Digital Engineering Lead, Compulsive Problem Solver.
