Where the heck is the OLE excel file
Joe-Bouza
Mentor Mentor
Joe-Bouza
Start off with I do not like using OLE but I'm working on one because the user isn't around.
This is very messed up.
No one know where the excel file is so I open through the OLE. make about two hours of changes save save excel. Drawing table looks good. close excel. ACAD crashes before I could save >>> open and the excel table is the old OLE .... Where the heck is the EXCEL file I edited and saved?
Joe Bouza
AllenJessup
It's possible it wasn't saved. Like editing and attachment in an email that wasn't saved out of the email. Select the OLE and in Properties  under Misc. If the Type is Linked. The file is somewhere on the network and you can open it and save it from the drawing. If the Type is Embedded. You can't.
Excel had recovery tools. See it you can find anything there.
Allen Jessup
CAD Manager - Designer
VincentSheehan
Check the Temp folder.
c:\Users\%USERNAME%\AppData\Local\Temp\
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Joe-Bouza
I had hope but nothing is there...But Wait! it is in a bak file in the temp folder
Joe Bouza
Joe-Bouza
Found a BAk file with the OLE (imbedded ... how dumb is that)
Joe Bouza
