Hi everyone,
I just need to get it off my chest.
I started working with C3D 2020, like with other new version my hope is Autodesk fixed the common bugs, but NO the bugs are still here.
So my question to Autodesk, when are you going to fix all these annoying bugs? I am working with AutoCAD since 1995 and I can't believe that in 2021 we are still faced with crashes occurring while using simple commands such as: pan, zoom, polyline, dist, etc. don't get me started with corridors - it's a nightmare. And it's not just me, it's all users here and in my previous jobs. C3D is so sensitive, it could learn heaps from other software packages that don't crash on hourly basis.
A simple example which doesn't make sense. I opened a drawing which had a title block and an xref, nothing else - no lines no additional annotations, absolutely nothing. So I changed the revision, ran audit and purge, and all good. Then out of the blue it crashed, after recovering the drawing accumulated 20 errors - from what?
Thank you for listening. Have a good crash less day 🙂
Regards
Not a happy user
I won't say that I don't get crashes, I don't think there's anyone here who can say that, definitively. But not often. Could you have hardware that isn't sufficient, was the drawing with 20 errors, started in C3D, is it a older file?
Here's one thing I do when going to a new version, and maybe it will make your world a little better. I always create a new template for each version (don't use the NCS dwt). So I create a blank dwt and import my styles settings, blocks , layers, description keys etc.... via either the Import Styles, Design Center and/or Drag&Drop.
Rick Jackson
Survey CAD Technician VI
Have you run -purge, regapps on your template to get rid of any unused apps that may have accidentally been saved from an architect/HVAC/etc?
Nancy
That, is a big issue. You must be running C3D basically as a power user, full admin rights - even at server level. Massive issues will disappear.
I realize your a large organization, but something I do even for my small one that works well in make sure that all support files are local to the user. No searching on the network... Plot Styles everything... with a lots of users this can be set up via batch copy/update, and standard profile setups by CAD/IT Management.
Rick Jackson
I concur Rick
For years I wasted time setting up common search paths to network location thinking I was doing the correct IT thing.
I switched to OOTB local and have seen a vast improvement
Joe Bouza
Do you have Sheet set manager running? I only say because if the default refresh is set and all your users are paging out the the server the pipe line gets pretty busy.
The 20 errors after crashing in a simple file is not really astonishing When you recover a file all it does is sort through the drawing database. when you crash actions and commands get interrupted and don't close out properly leaving the database with incorrect, unfinished lines. those line are the errors that are being fixed .
That my caveman IT knowledge of it.
Joe Bouza
Hi everyone,
thank you for all your help so far, to add few things to our problem, we experience the following: C3D 2020 won't create or save bak files, also I have this dwg here which I saved last night and this morning I can open it as read only. I know no one else is using it because otherwise it would show me the initial of that user. To top it up, C3D 2018 opened up without the ribbon which tells me my profile or cuix file got corrupted.
Regards
Peter
OOTB = Out Of The Box.
Christopher Stevens
OOTB = Out of The Box.
The suggestion is to store files on the local computer, at whatever location C3D defaults to.
If these are "standards," managing/synchronizing them on multiple computers is an IT task to be handled outside of AutoCAD/C3D.
This does not seem logical to me, but it may be a best practice.
Autodesk is investing a lot in interoperability and BIM 360 (that may not be the latest name.)
This commitment/investment may encourage/force the C3D team to make C3D "play nice in the cloud."
This could result in some collateral benefit to non-cloud users, such as resolution of some of these long standing issues.
I am hopeful, but do not recommend that you hold your breath.
Christopher Stevens
If you have to run AUDIT/PURGE to fix a problem, your issue is your DWG files. Might be time to let an intern at the company run RECOVER/RECOVERALL commands on all files and xrefs for a day.
C3D 2020 has updates that are required: do you have them all? Prove it, post a screenshot of your ABOUT command.
Also post a screenshot of your GRAPHICSCONFIG command pop-up: you appear to also be describing a video card/driver that may be inadequate (regardless of what make/model you have).
FYI no one here is Autodesk: only fellow end users like you with jobs are here to help each other out. If you want Autodesk Support then log into your Autodesk Account Page, find the ? icon, and start a support ticket.
TIA
Hi Dean
I concur with the advice.
maybe you know something on this. Why doesn't the file open command simply include the recover / audit scans?
Over the years I regularly use recover just to open files. Id say all the time but sometimes I don't but I do tend to think in that order; to open with recover
Joe Bouza
@peter.fierek wrote:<<I opened a drawing which had a title block and an xref, nothing else - no lines no additional annotations, absolutely nothing. So I changed the revision, ran audit and purge, and all good. Then out of the blue it crashed, after recovering the drawing accumulated 20 errors - from what?>>
That might be your trojan horse. I be more worried about the xref and template than with AutoCAD. Templates and xrefs are living entities. They can grow, be edited and get corrupted. If it appears innocuous it might actually be the most damaging. Cynicism has its place.
Chicagolooper
Joe uses these high tech phrases all the time.
OOTB
Out of the Box.
Bill
