whats problem when i import subassembly from version of the subassembly composer 2018 to civil 3d 2020
giscivil92
Message 1 of 17
giscivil92
Hi @Everyone
I created a subassembly by subassembly composer 2018 in another system but when I open it in civil 3d 2020 in another system it's broken!?
Replies (16)
Message 2 of 17
snoyola
@giscivil92
Please could send me your PKT, to [email protected],
Simon Noyola Rivero
BSI Tutor 19650 BIM MEXICO LATAM
BIM Infrastructure SME
(DTE & DDSCAD & Autodesk Global Provider Select)
Autodesk Authorized Consultant
Subject Matter Expert Civil & Map
Civil 3D Country kit development
Autodesk Certified Instructor
USA, Mexico, Central America, Caribbean & Venezuela
Message 3 of 17
giscivil92
@snoyola Hi
I just sent you
Message 4 of 17
snoyola
Use wetransfer because is possible block in email account
thanks!
simon
Message 5 of 17
giscivil92
Hi @snoyola
Unfortunately, I have that problem!
Message 6 of 17
Udo_Huebner
Open the PKT once in Subassembly Composer 2020 check itand resave it (don't miss to make a backup). Then try IMPORTTOOLS with this resaved PKT file. Does it work as expected in C3D 2020 then?
Gruß Udo Hübner (CAD-Huebner)
Message 7 of 17
giscivil92
@Udo_Huebner  Hi
It wasn't solved again.
you can try the attached file.
Message 8 of 17
snoyola
Message 9 of 17
giscivil92
 I have had this problem yet!
Message 10 of 17
snoyolar_ddscad
@giscivil92
Please try again, check your email
simon
Message 11 of 17
Udo_Huebner
@giscivil92
I don't see an attached PKT file in this thread, otherwise I'm happy to review your file.
maybe @snoyolar_ddscad can attach the files for us.
Message 12 of 17
giscivil92
@Udo_Huebner
I attached the file
Message 13 of 17
Udo_Huebner
I assume, the sub-assemblies are not found, because they were renamed.
The uploaded type1_test.PKT files works like a charm, but "canal_type1_test" is still missing in your drawing.
Message 14 of 17
giscivil92
@Udo_Huebner
I just renamed the name.
You can try with original name
I have tried but didn't work
Message 15 of 17
Udo_Huebner
What Civil 3D Version you are currently using?
Message 16 of 17
giscivil92
I'm using civil 3d 2020.
But I created the pkt with subassembly composer 2018 and imported into civil 3d 2018
Message 17 of 17
Udo_Huebner
Sorry I have no older Civil version available to test. But with 2024 the PKT files work as expected.
