How can i define topsoil in subassembly composer !?
giscivil92
giscivil92
Hi @Everybody
How can I define topsoil in subassembly composer for example cut 10 cm of the top of the soil while the cross section is in the fill mode like this image!?
Udo_Huebner
"Topsoil" is only a shape code. You decide how to proceed if a subassembly point is below or above a target surface (existing ground - EG). If the test point P1 (edge of travelled way - ETW) is above the surface, a P3 should be created that is 0.1 m below P2 (slope staking point).
Therefore, an auxiliary point AP1 is usually created vertical from P1 to the surface. Then check P1.y > AP1.y in a decision.
But in this case, wouldn't you do the same if P1 is below the EG?
Gruß Udo Hübner (CAD-Huebner)
giscivil92
@Udo_Huebner Hi
Can you show it in a video I don't understand what do you mean!
giscivil92
If anyone knows I appreciate to help me.
fcernst
Use two Surface Links.. giving the second one a Depth below EG.
Then close the ends and create a Shape for it..
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
