What Controls Sump Elevation?
sbrownE7LKK
Message 1 of 8
sbrownE7LKK
I have been spent the day creating a pipe network and have come to find out the Sump Elevation for my manholes are 500ish feet lower than my rim elevation. How could this have happened and is there any way to fix this?
My "Control Sump by:" is set to depth, and I'm using the "basic" rule set.
Replies (7)
Message 2 of 8
fcernst
Relative to the lowest pipe invert.
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
Message 3 of 8
sbrownE7LKK
Lowest invert per network or per structure? @fcernst
Message 4 of 8
MMcCall402
The invert of the lowest pipe connected to the structure along with the structure rule for sump depth. (if such rule is being applied to the structure)
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 5 of 8
sbrownE7LKK
@MMcCall402 I have an Invert in of 598.81, Invert out of 598.61, how could my sump elevation be 114.28?
My Set sump depth rule is set to 0.00
Message 6 of 8
MMcCall402
Did you apply the rule?   (select the structure and choose Apply Rules from the right click menu)
Mark Mccall
CAD Mangler
Message 7 of 8
fcernst
Per structure, of course
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 8 of 8
sbrownE7LKK
@MMcCall402 that fixed it. I don't understand why it was that in the first place though. When creating structures do you need to apply rule each time after setting invert elevations?
