I'm trying to Align and Scale a set of COGO points to another set of points without changing the elevations.
Is there a way to do this?
Context:
We have a problem with a site localization/calibration for a GPS topo survey. We need to rotate and scale our latest points to our control points without changing the elevation values.
I've drawn a common baseline in each set of points, flattened both line(s), then I used the Align command and selected Y to scale to the flattened endpoints of each line. However, the Z values / elevations keep scaling up, too. The Z values don't change when just Aligning, however, when I try to use the Scale command (either as part of my Align command or separately after Aligning the points w/o scaling) the elevations keep scaling.
If I can't get this to work, I'm considering scaling the points, exporting a CSV file, then copy/pasting the correct/original elevations into the CSV of scaled X/Y coordinates. But this seems like a bit of a workaround for something that should reasonably be achievable in Civil 3D.
Thanks!
