When trying to add water drop lines on a surface from a Layout, when I try to add a point nothing happens and "Point outside surface" shows on the command line.
Instead, when I go to the Model Space, I can always add the water drop lines by clicking exactly on the same points for which I get the "Point outside surface" on the Layout. When going back to the layout, the water drop lines are there.
Any ideas what may cause the issue?
