- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello All,
I at a loss as to why this simple function is not behaving correctly. I have two surfaces, created as typical, one containing existing contours with correctly assigned elevations and the other containing proposed contours with correctly assigned elevations. However, when I create my Volume TIN Surface, the contours generated seemingly do not relate to the existing topo surface. In fact, they close in on themselves and create a totally unusable surface for comparison.
Again, both surfaces were created normally, by importing pline contours from an AutoCAD file. My proposed contours were snapped to the existing and contain the matching elevation information. This is confirmed when orbiting the surfaces in Civil3D.
Please refer to the images below to view the results I have described.
Has anyone had this problem in the past or have an idea as to what might be causing this malfunction?
Thank you
