Civil 3D Forum
Volume Surface Grading Incorrect
9 REPLIES 9
Message 1 of 10
1237 Views, 9 Replies
Hello All,
I at a loss as to why this simple function is not behaving correctly. I have two surfaces, created as typical, one containing existing contours with correctly assigned elevations and the other containing proposed contours with correctly assigned elevations. However, when I create my Volume TIN Surface, the contours generated seemingly do not relate to the existing topo surface. In fact, they close in on themselves and create a totally unusable surface for comparison.
Again, both surfaces were created normally, by importing pline contours from an AutoCAD file. My proposed contours were snapped to the existing and contain the matching elevation information. This is confirmed when orbiting the surfaces in Civil3D.
Please refer to the images below to view the results I have described.
Has anyone had this problem in the past or have an idea as to what might be causing this malfunction?
Thank you
Tags (1)
9 REPLIES 9
Message 2 of 10
tcorey
Contours for the volume surface won't necessarily follow existing ground. These contours are based on the difference between existing and finished. A contour at 5' represents the line where your fill is 5'.
Post your drawing and we can take a look so that we can give specifics.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 10
in reply to: tcorey
tcorey- thank you for taking a look.
I have attached the file.
Message 4 of 10
tcorey
I took a look at your file, compared the elevations of the polylines used for eg and fg. The volume surface is giving the correct results.
Maybe you don't fully understand what volume surface contours are showing you. When you display contours for a TIN volume surface, they represent the depth of cut or fill at that point, the difference in elevation between the base and comparison surfaces. These contours might look nothing like the OG or the FG contours. If you create spot elevation labels on this TIN Volume Surface, they will show depth of cut or fill at that point.
There is one possible gotcha. Your fg polylines go from 9308 directly to 9312. There is no 9310. It won't make much difference if the two elevations are correct, but I thought you should know, in case it's an input error.
Tim Corey
Redding, CA
Message 5 of 10
in reply to: tcorey
Thank you Tim for clearing that up.
I am new to this program and my tutorials did not explain what a Volume Surface and it's contour signatures actually represent.
Message 6 of 10
wfberry
Just remember, GOOGLE is your friend and a lot faster than this forum. (sometimes)
Bill
Message 7 of 10
in reply to: wfberry
Thanks Bill,
Google was not as friendly as I expected. 2 of us had been googling and
trying to figure this issue out with no avail so I am thankful for this
forum- even if I had to wait a few minutes for a reply.
Message 8 of 10
wfberry
Please don't shoot the messenger.
I am just trying to help.  Here is how I use Google.
Civil 3D, Volume surface
Bill
Message 9 of 10
Bill,
I know, I did not intend to come off as unappreciative. Thanks for your
input.
Message 10 of 10
tcorey
Yes, Google is your friend, but we're your friends, too.  😉
Anything you ask here is potentially an answer for someone else. That's a good thing.
Keep posting.
Tim Corey
Redding, CA
Rail Community
