Volume dashboard problem
Message 1 of 13
Hi
I have a problem with calculation of volumes. I tried volume dashboard and alignments-section method but always i got the same "wrong" cut and fill value.
And i looked the new surface whom created by volume dashboard. I saw this
2 surface with one created refence to other2 surface with one created refence to otherThe surface which volume dashboard createThe surface which volume dashboard createDistance between 2 surfacesDistance between 2 surfaces
Replies (12)
Message 2 of 13
neilyj666
This behaviour is as designed because the volume dashboard creates a TIN volume surface which represents the level difference between the surfaces.  The Z values will be scattered above and below the 0 datum
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 13
So , is there any solution?
 My surfaces has Z values bdw
Message 4 of 13
Joe-Bouza
What’s wrong?
Joe Bouza
Message 5 of 13
neilyj666
What solution do you expect .... there's nothing wrong with this as I have already stated.
The red surface is fully below the other surface so the Z values in the volume surface will all be negative -as expected
Message 6 of 13
when i calculated volumes i am gettin very very wrong value like original value is 18000 m3 i got 400 m3
Message 7 of 13
neilyj666
You'd be better posting the dwg so someone can look at it
Message 8 of 13
i will do that in monday at work than
Message 9 of 13
here it is
Message 10 of 13
BrianHailey
In your post, you state the volumes in cubic meters but the drawing itself is in feet. The 400 m3 to 18000 m3 discrepancy is very close to the conversion factor between cubic meters to cubic feet.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 11 of 13
Thanks a lot .I change the drawing units to meter and i changed all of ambient settings to meter it was a mess bdw 🙂 and now i got the right value. Thank you again.
Message 12 of 13
Last question. how can i change defaults. I picked yes in save change settings but it goes back when i start new drawing
Message 13 of 13
BrianHailey
You need to change the settings in your template. When you start a new drawing, it basically copies the template and names it Drawing1.dwg. If your units are set correctly in your template, they will be set correctly in the new drawing.
GEI Consultants
My Civil 3D Blog
