Just again had locked viewports reset to 0,0. I've seen that it might be related to dynamic north arrows, does anyone know if this is the case. I have had them move on a number of drawings now and I do use the dynamic arrows.
thank you,
Tom Oines
Civil 3d 2014
thank you,
Tom Oines
Civil 3d 2014
Make sure VISRETAIN is Set to 1 and USCFOLLOW to 0 (zero)
Just had a file, with five sheet tabs, each with one locked VPort.
All worked well.
Now, only one VPort is in the correct location - all others centered on 0,0.
VisRetain and UCSFollow okay...kind of a pain to reset.
Any new thoughts?
All worked well.
Any new thoughts?
I am having the exact same issue. The setting "VISERETAIN" is set to 1 and the setting "UCSFOLLOW" is set to 0. Viewports in other layouts seem to reset to 0,0 after rotating the view in the current layout. I would really like to find a solution to this. Anyone have any ideas?
@k_niedzielski wrote:
I have checked all of my viewports and every single one has UCSFOLLOW set to 0. Any other ideas?
UC ↵
Settings -> save UCS with viewport?
UC ↵
Joe Bouza
Joe Bouza
My UCS is set to world in all of the layouts. I normally don't change the UCS. I am currently using Civil 3D 2016 and use the "Layout Elements" tools in the "Layout Tools" ribbon. So far it seems that the viewports reset to 0 after I copy a layout multiple times and rotate the view in each copy.
Sorry to open such an old wound, but was this ever resolved? This is the first time I've ever seen this happen, but I am also setting up sheets with the view frame group tool (plan/profile) with a dynamic(ish) arrow.
I hereby and forthwith ban the use of all dynamic arrows!
I would like to second that motion! It is clear they are too dangerous and cannot be trusted!
My Mantra for years
Joe Bouza
My Mantra for years
Joe Bouza
Hello all,
one last thought . . . .
viewports that are locked, with different scales in one drawing can cause the same problem.
saw this in 2014 and 2016. and do not care to findout about 2018.
good luck
nonbeard13
Hello all,
good luck
nonbeard13
yep. dealing with it now.
Still not fixed in 2023 version. Funny thing is that the preview shows the viewport correctly but switching to it resets it to 0,0. Thanks autocad I have to probably redo 50 P and Ps. Mine was triggered after a purge all command for what is worth.
My .dwg with 20 Tabs with one vport each containing dynamic north arrows all reset...but all the vports with no dynamic norths were OK.
Is there a way to save each vport location so I can just reset without having to pan by hand?
