Civil 3D Forum
Viewports moved when locked
22 REPLIES 22
Message 1 of 23
3303 Views, 22 Replies
Just again had locked viewports reset to 0,0.  I've seen that it might be related to dynamic north arrows, does anyone know if this is the case.  I have had them move on a number of drawings now and I do use the dynamic arrows.
thank you,
Tom Oines
Civil 3d 2014
thank you,
Tom Oines
Civil 3d 2014
22 REPLIES 22
Message 2 of 23
mconway
mconway
Make sure VISRETAIN is Set to 1 and USCFOLLOW to 0 (zero)
At your service,
__________________________________________________
Mark A Conway –Director of Design Technology | Gilmore & Associates, Inc.
Autodesk Certified Instructor
AutoCAD Civil 3D Certified Professional
Autodesk Certified BIM Specialist for Roads and Highways
At your service,
Message 3 of 23
in reply to: mconway
Just had a file, with five sheet tabs, each with one locked VPort.
All worked well.
Now, only one VPort is in the correct location - all others centered on 0,0.
VisRetain and UCSFollow okay...kind of a pain to reset.
Any new thoughts?
All worked well.
Any new thoughts?
Message 4 of 23
k_niedzielski
k_niedzielski
I am having the exact same issue.  The setting "VISERETAIN" is set to 1 and the setting "UCSFOLLOW" is set to 0.  Viewports in other layouts seem to reset to 0,0 after rotating the view in the current layout.  I would really like to find a solution to this.  Anyone have any ideas?
Message 5 of 23
igi_pop
igi_pop
Ucsfollow is a per-viewport setting as far as i remember..had that issue ages ago. Especialy painfull if you copy the viewport 10 times ant THEN learn that 🙂
So, for each viewport, double click inside it to enter into model, then UCSFOLLOW - 0, set it up the way you want it and ext to paper space.
Rinse and repeat
Wax on wax off so to say 🙂
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
Rinse and repeat
Message 6 of 23
k_niedzielski
in reply to: igi_pop
k_niedzielski
I have checked all of my viewports and every single one has UCSFOLLOW set to 0. Any other ideas?
Message 7 of 23
igi_pop
in reply to: k_niedzielski
igi_pop
UC
Settings -> save UCS with viewport?
UC
Tags (2)
Message 8 of 23
Joe-Bouza
Joe-Bouza
Is it written somewhere? Maybe. Does it happen in 2014 ? Yes with dyno arrows; especially if the sheets were made with PP tool.
Joe Bouza
Joe Bouza
Message 9 of 23
k_niedzielski
in reply to: Joe-Bouza
k_niedzielski
My UCS is set to world in all of the layouts.  I normally don't change the UCS.  I am currently using Civil 3D 2016 and use the "Layout Elements" tools in the "Layout Tools" ribbon. So far it seems that the viewports reset to 0 after I copy a layout multiple times and rotate the view in each copy.
Message 10 of 23
tswartzfager
tswartzfager
Sorry to open such an old wound, but was this ever resolved? This is the first time I've ever seen this happen, but I am also setting up sheets with the view frame group tool (plan/profile) with a dynamic(ish) arrow.
Timothy Swartzfager
CAD Monkey Extraordinaire
Civil 3D 2020
Timothy Swartzfager
Civil 3D 2020
Message 11 of 23
mconway
in reply to: tswartzfager
mconway
We ended up exploding the North Arrows this disconnected them but the VPs acted properly
At your service,
At your service,
Message 12 of 23
tswartzfager
tswartzfager
I hereby and forthwith ban the use of all dynamic arrows!
Timothy Swartzfager
Civil 3D 2020
Timothy Swartzfager
Civil 3D 2020
Message 13 of 23
k_niedzielski
I would like to second that motion!  It is clear they are too dangerous and cannot be trusted!
Message 14 of 23
mconway
mconway
DILLY DILLY!
At your service,
DILLY DILLY!
At your service,
Message 15 of 23
Joe-Bouza
Joe-Bouza
My Mantra for years
Joe Bouza
My Mantra for years
Joe Bouza
Message 16 of 23
Hello all,
one last thought . . . .
viewports that are locked, with different scales in one drawing can cause the same problem.
saw this in 2014 and 2016.  and do not care to findout about 2018.
good luck
nonbeard13
Hello all,
good luck
nonbeard13
Message 17 of 23
jmayo-EE
jmayo-EE
Still in the product.
John Mayo
John Mayo
Message 18 of 23
nostupidquestions
yep. dealing with it now.
Intel(R) Xeon(R) W-2245 CPU @ 3.90GHz 3.91 GHz
64 GB RAM
C3D 2023.2
64 GB RAM
C3D 2023.2
Message 19 of 23
arodriguezDQBHW
Still not fixed in 2023 version. Funny thing is that the preview shows the viewport correctly but switching to it resets it to 0,0. Thanks autocad I have to probably redo 50 P and Ps. Mine was triggered after a purge all command for what is worth.
Message 20 of 23
millermccoy
My .dwg with 20 Tabs with one vport each containing dynamic north arrows all reset...but all the vports with no dynamic norths were OK.
Is there a way to save each vport location so I can just reset without having to pan by hand?
2015 Civil 3D
2015 Civil 3D
Rail Community
