I have contour labels that I am needing to show in a different text style in a separate viewport, but keep it as is in the current viewport. Is it possible to viewport override the line label styles?
Joe Bouza
In my case, based on my object layer settings, contour label are placed on layer C-Topo_Text-<surfaceName> , but the components can be on any other layer allowing control. You could probably monkey around with the ambient setting object layers but I believe you will get to the same place.
Note in the example I used proposed and existing style only because I knew I had two with different settings. you can do it your way
You can do this two ways noting that the snow flake only works on the base layer:
1. grab all the labels of one style and force them to a seperate layer and snow flake in the vport
2. open the layer dialog box and freeze the component layer of the ones you dont want to see
Joe Bouza
It seems that I have mis-read your post. No. AFAIK you cannot have two text styles in one contour label style on different layers, but you can label it twice as indicated.
Joe Bouza
